13 to 14 inch prop
Crownie2
Re: 13 to 14 inch prop
Tacklewasher - Check out the drop down under "Interact" for the edit option.
Cook manufacturing makes a 4" manually adjusted setback that should run less than $200. Because it may spread out the load it may not be as stressful on the transom as you think.
In addition to allowing for infinite adjustment of height it will give you more bow lift.
Check out cook-mfg.com
Bob
