Would switching from a 21 pitch Vipor to a 22 pitch Raker make much difference in performance?
1 1997 cajun Cadet Thread starter Joined Jan 7, 2008 Messages 18 Mar 24, 2008 #1 Would switching from a 21 pitch Vipor to a 22 pitch Raker make much difference in performance?
D Dhadley Supreme Mariner Joined Feb 4, 2001 Messages 16,978 Mar 24, 2008 #2 Re: 130 Johnson prop question Loaded question. The Raker will have more lift so if the set up is maxed out with both props, the Raker should be better. If the set up isn't maxed out for either, then all bets are off on both.
