cacookie
Thread starter- Joined
- Sep 20, 2009
- 4
Overheat buzzer is sounding after a couple off minutes use. I have replaced the impeller and it is pumping water out thru the exhaust and the outlet at top of leg. Removed the tell tale screw from top off block, and no water coming out at idle, and only a gurgle coming out at half throttle. when i checked the thermostat it didn't have one installed. is there any thing i should be looking for.
Thanks.
Thanks.
