135hp Mercury Outboard will not turn over
Faerbairn
I am trying to start a motor I just picked up. It doesn't do anything when I turn over the ignition, but when I release the ignition from the start position, then it slightly turns. What do you think is the problem?
Also, what year is the outboard? 2 cycle, right?
Thanks for your help.
135hp Mercury, 6 cylinder, Ser # 2504413
j_martin
Re: 135hp Mercury Outboard will not turn over
Bad ignition switch.
If you're going to try to repair things, get a mercury service manual as your initial investment.
Also, learn to be real clear about what you're doing. I have to assume that by "turning over the ignition" you mean twisting the key.
