Ok, guys, thanks for all the advice yesterday. I'm back for some more. :redface:
The pics are to show the paint a little bit. You can really see it better in the picture of the inside of the boat. It feels "chalky." Not sure if that matters.
My son wants to strip the boat we got down to the bare aluminum. The boat has a few layers of paint. Some of it is starting to chip off. He's not comfortable painting it until his dad is able to help, but since this is a surprise for his dad, he wants to make it look good.
We bought some of the Strip Klean for Aircraft (2 spray bottles) yesterday. He will begin using this tonight. He wants to know if he should just use this and some sort of plastic scraper or just a the power sprayer to clean the paint off. He will also need to remove the numbers (adhesive) that are currently on the boat. He thought he should probably avoid sanding if he is planning to polish up the bare aluminum...
He was also curious if there is something he could use inside the boat to "paint" onto the seals and rivets - or if he should - as a leak preventative. The boat does not currently leak. He just wanted to know if there is something he should use up front to prevent leaks.
Lastly, there is carpet in the bottom of the boat. He is wanting to carpet the sides but does not want to apply the carpet directly to the aluminum. We have read that you can use wood and wrap it in carpet. We also read about foam, which would be much easier for him to work with. The question with this is - wouldn't the foam covered carpet sides blow right out of the boat? Or is there a way to attach them that's not 100% permanent. Also, would the foam mildew or soak up the water? We went to Home Depot yesterday and looked at the sheets of foam. There were light blue foam sheets that were pretty stiff. Probably about 3/4" thick... Is this the right stuff?
Thanks!!
