Riley C
Thread starter- Joined
- Dec 23, 2018
- 239
Hi All,
I hope all you fellow boaters are enjoying great times on the water, engine free.
On my 87 140 Looper:
I’m having a little issue with plugs at present. Mainly with plugs fouling. See pics below.
I have just swapped them from NGK BR9HS10 to Champion QL77JC4 today. Hopefully this will make them burn better. But I’m really curious about the uneven burn on them.
The port cylinders are the same, but different to startboard, with its half clean half brown?
The big thing I notice is after warming up I get a power surging at WOT. This surge is at 6k rpm, it does go after running for an hour.
Could the spark advance be to much?
Just recently completed:
Running SST 13.5x19 prop
coils are cdi in port side, Omc on starboard
power pack replaced in 02, has done 200hrs since
carbs cleaned, vro replaced with vacuum pump
new thermostats, water pump
New fuel lines throughout even to carbs, with new fuel filters
flushed fuel tank
Reed valves cleaned and fitted new gasket
Head gaskets replaced
Compression at 115 on three and 125 in the other.
I have learnt the loopers don’t like idle revs at all.
Any advice would be a big help.
flushed fuel tank
