140 hp OMC sea drive
fishtilubleed
I have a 1988 OMC 140 hp v4 sea drive with a bad prop shaft. Any tricks to drop the lower gear case? I have service manual on the way. Do any other lowers interchange with this model? Thanks in advance.
Crosbyman
just unbolt and disconnect the shift rod #36 up top should do it
see under the trim tab do no remove #71 anode bolt
Propshaft is fitted on many years of Johnson / Evinrude V-4 models.----Your location?
