greaseball04
Thread starter- Joined
- Aug 6, 2008
- 4
Was out over the weekend. (140 hp 1982 johnson). Boat ran like crap. Lots of misfiring and sputtering with the ocassional smooth run. I had a similar problem earlier in july and bypassed the fuel filter and it seemed to clear it up. Over the weekend I removed the motor cover to check my plug wires etc. I noticed that the engine would run much better with the cover off, but it was way to loud to enjoy boating. A couple days ago I checked my plug wires and determined that one was pooched, so that has been changed. While I was at it I changed all my fuel lines to 3/8 up from the original 5/16 lines (boat originally had an 85 Force), from some reading on the forum the suggestion it that the 140's like the larger diameter lines, and also installed new spin on fuel filter.
Today I took it out and could not get above 3000rpm. I beached and started looking at the cam follower position. I noticed that I was not getting WOT based on the position of the butterflies in the carb when the controls were pushed to the WOT spot. I adjusted the follower and WOW what a difference. The 17' foot bayliner goes like stink and has tremendous holeshot.
