Riley C
Thread starter- Joined
- Dec 23, 2018
- 239
Hi guys,
Im having issues with power and and wot revs and pretty stuck on this one actually. Today I went for a run and we could barely get a skier out of the water.
The engine would get over 5k and really labour’s in 2-3k rev range. Usually handles 6k at 85km.
The compression is 110psi on all four.
I did another lync in the test tank. With idle at 800 and slightly moves in out of that.
I don’t get how all of a sudden there is barely any juice in the power band. Can out of sync do this but idle fine?
What is the absolute best lync method on the loopers? My genuine omc states different to joe reeves. Joe says bisect point and roller centre when valve plates start opening.....? Omc says centre at start but I have bogged out from this.
Is there another area I should be looking? Sparks on all cylinders otherwise I wouldn’t be getting 70km/hr.
I have a 1994 130 spare. So could swap some parts out that. Such as powerpack if needed.
Tried, carbs have been cleaned, new plugs and leads. Hoses and filters are new also.
Two trips ago we had what was thought to be a fouling plug, idle to long. With power loss at wot in and out really starting around. Plugs were replaced but full power not restored. I get spark to all cylinders.
Any suggestions would be a big help. It was running sweet for months.
