trevtt600
Thread starter- Joined
- May 17, 2009
- 80
1978 Mercruiser 140, Delco distributor. I have a dial-back advanced timing gun. When you set the advanced timing, do you subtract the intial timing of 6 from the 35@2000 and set the gun to 29 degrees, or do you just set the gun to 35 degrees and move the distributer to match TOD. After the advanced is set, what do you do with the intial? do you go back and reset the intial, or just adjust the idle.
