140 Mercruiser Fuel Filter
bbook83
I was tracking down a stalling problem in my 1974 mercruiser 140 and checked the fuel filter in the ”bowl” on the top of the fuel pump. When I removed the filter, both of the metal ends fell off, revealing ugly white material that left pieces all over, as shown in the attached photo. I put the bowl back on with no filter and ran the boat with no stalling problems. I plan to check the carb bowl for debris and replace the filter with the proper Mercruiser part. I think the one that failed was a Sierra, and only about one year old. Has anyone seen a filter fail like that? Is this another result of ethanol, or something else in the gas, or just bad adhesive holding the metal pieces to the paper portion?
Ayuh,..... Ethanol, 'n water will do that,....
bbook83
Thanks Bondo. I hadn’t considered water as being a cause. Perhaps it is time for a fuel water separator.
