Re: 140 mercruiser missing after it gets warm
I took the boat out sunday and it ran as it should.
lane:No sputtering at the 30 minute mark . The only thing I did was I moved the ign coil away from the motor by mounting it on a piece of 6" all thread and insulated it with a beer coozie . I also noticed that the engine ran about 20 degrees cooler than it had been running before, even though it was a good bit hotter on sunday .
Of coarse I don't think moving the coil had anything to do with the engine temp changing .
I'm thinking that the whole thing was caused by the engine running hotter than normal and the coil being mounted right on the engine was causing it to overheat and break down . As to why the engine was running hotter than normal all I can come up with is that maybe the new outdrive was running hotter during the initial break in period . I'm about 7.5 hours into the 10 hour break in , Maybe things began to losen as they broke in and now its back to normal operating temp .
can't say for sure I'm just glad its running good again and I hope it continues to do so .
I'm still going to mount a couple of clam shells on the motor cover to scoop some cool air into the engine compartment .
Thanks for all the help guys especially MikDee whose given some great tips through all this .
i will give an update again soon just to let you know if its holding up . if it isn't I'll be back crying the blues:sour:
