SSTKO81
- Joined
- Jun 1, 2009
- 354
If fuel is getting there and you're confident float level is correct and it won't idle, despite multiple rebuilds somewhere your idle circuit is clogged.
at higher rpms where it runs carb idle transition slots and main venturis start feeding fuel.
I’m not confident in the float level. That’s what I’m getting at. This carb number registers to a 250 that called for different float specs than the 140. But the 140 was never equipped with this particular carb. So I’m going to take the carb back off and reset the float according to 140 spec and try again
