Re: 140hp Evenrude Blown Head Gasket
There was no rust in the cylinders and they have never been frozen. I lubed everything up in there and stuck a dry clean rag in both and one over them before covering it for the few days before the head gasket arrived.
Very helpful Even/John mechanic at the local shop suggested before machining (he might even have a good used head laying around) that I do a decarb and get it warmed up and then re-torque. He said the compression is not terrible. If I can get another 5psi out of it I would be in range and I’ll let it go. He mentioned that the warming up of the gasket and re-torque might just do the trick if its a leak at the gasket. I’m going to try that tonight and see how it goes.
If not I’ll go with the machining or a used good head. I’ll do your ring check thing at that point as well.
Thanks for the help Ill report back once I have a solution or not.
If you were sure that the mating surface on the block is in good shape I wouldn’t be concerned with the gasket for now, take the head off and bring the piston to the top of the stroke and check for a slight bit of motion between the cylinder and piston, which would mean to me that the rings are free to move. It’s not good if the rings are locked.
Did you notice a rust ring on the cylinder wall when you first got a look at it? Saltwater did enter the cylinder and if it had enough time would have caused the ring to rust and stick to the cylinder wall. It’s good that the piston still moves.
If there is movement, and the worm grooves are on the head only, then have the head machined (my guess is a fifty buck job). The gasket is probably done for as general use but should work to do a compression test. If the cylinder comes back to life I would pull the other head and have that machined and replace both gaskets.
