140hp outboard waterpump question
robmcconnell
Hi All
I have a 2000 mercury 140hp 2 stroke outboard.
I changed my impeller and put a new housing in. All went well and took the boat our for a test run, it ran between 140 and 170 so very happy. The tell tale was nice and strong. The only problem was that the speedo does not work and I realise that the little pipe going into the gearbox must not have been connected when I put it back together.
The question is that when I ran fresh water through the engine after I had used it, I noticed that when I stopped there was water coming out of the two square annodes on each side of the leg. I might be paraniod but should water be coming out of this part of the leg, or could it be to do with the pipe that is loose from the speedo.
Thanks in advance
Rob
79Merc80
Re: 140hp outboard waterpump question
I didn't know that Mercury made a 140hp 2-stroke past 1981. Do you have any pictures?
Craig
