14ft aluminum transom repair
Uglylure
Ahoy all, glad to be aboard..right to the point...here are some pics, recommendations please jeffboat.jpgAppreciate all the help..hoping to launch 24 weekend...trailer bunks also in the works...read a lot of transom repair threads...definitely helped a lot, told friends, if they need an answer, come to I-Boats.
jbcurt00
Welcome
You need transom end caps. The busted ones can be replaced, but probably not quickly or w factory originals. Its often a waiting game.
Check ebay, there may be some similar enough to work.
Cut new 3/4in plywood to fit, seal it and install it front and back of the transom skin. The piece on the outside was probably shaped similar to a baseball home plate. The inside piece was gunwale to gunwale
Weldorthemagnificent
I did one similar last year. i didn't put wood on the outside. I laminated/glued two pieces of plywood together to achieve the thickness between the transom and the bracket. Treat-varnish-paint the wood so it lasts. Use sealant around any through fasteners. As for the transom caps, I'd get a local fab shop to cut a couple corner gussets and bend down a lip on one side. The lip to the rear and screw-bolt-rivet them in. Good luck it looks like a cool old hull.
Woodonglass
I recently saw an aluminum fishing boat with DIY fabricated Transom Caps. Wish I would have taken pic. Basically the guy bout some 1/4" aluminum plate from eBay ($30) and cut/bent them to fit. This is a poor drawing but the results resembled this...
He said he cut them with a jig saw (as shown above) and then clamped them in his vice with some angle iron and then used a block of wood and 2lb hammer to make the bends at the orange lines. They really looked almost factory. He filed the edges round. I think he said the Aluminum plate was a 1/4" x 10" x 24" piece for that amount.
I'm pretty sure a "Handy" iBoater could do this!!!!:rockon:
Uglylure
Appreciate all the help all, I will post the finished product pics when all done..Happy Boating all, Thanks so much!
Uglylure
Boat pics as promised
I have to apologize for taking so long for getting these pictures uploaded(and hope it works). It was a fun summer project, lots of laughs with my buddy helping out. Still a few things to finish but here you go.
