14ft boat with 25 h.p.?
seyahjr
I have a 14 ft dbl wide dbl deep landau, an old 1968..... the tag on the back is no longer visible....i know the boat is rated for five persons.....is a 25.h.p. too much motor on this??I have a lot of old motors, im a tinkerer and i recently got an old 54 johnsoon that i've been super tuning........i guess what im asking is is this motor too big??? any idea what my boat is rated for??? i thought i read 35 h.p. on the tag years ago... but i cant remember and the tag is now so faded it can't be read...any answers??:cool::cool:
Whoopbass
Re: 14ft boat with 25 h.p.?
Your 25hp will be just fine on that boat. 35hp rated sounds about right for a boat your size.
lncoop
Yep. Normally a 25 is too much on a 14 footer, but yours is an exception. Should be fine.
Engine344
AHHHHH I do not mean to disagree, I have ran 35hp on 14' Starcraft boats for 20 some years, they are rated for them. With a transom in good shape, properly installed, and common sence a 25 hp can be ran all day long!
Disclaimer: I run a river, with that being said the demands on a 25hp (at times) "could" be harsh.
lncoop
You're right Engine. I should have been more specific as what I really meant was the average 14' jon, which is typically 36" to 42" wide and cannot safely handle a 25. There are pleny of 14 footers that can handle a 25 and more.
Engine344
Ohhh all good, to help your point there ARE 14' footers that are better with 15 or a 9.9. Was not trying to argue or shove my opinion down anyones neck..Just my 2 cents LOL I actually prefer a 25 on a properly sized 14 footer because there are times when you want/need the exxtra umpfff. :D
lncoop
Ya mon.:cool:
5150abf
Make sure your transom is in good shape, it was rated for 25 horse 43 years ago so if nothing has been done to that transom in all that time it may not hold a 10 horse.
It should be able to hold most of your weight standing on the engine without moving more than an 1/8'', the engine puts that much or more torque on the transom, if it won't hold you it won't hold your engine either.
chrome dome
please excuse the very late reply :D
just FWIW...probably not much now!
l have a 1968 Popular Mechanics book that has a graph in it from the Outboard Industry Association, can't scan it though,
basically you multiply the length X max width at stern to get MAXIMUM safe HP for your boat,
if your boat is close to 4 ft wide then this graph says 25HP,
l've tried this formula on a number of boats over the years and it's been spot on with the factory max HP plate
