15 hp evinrude powerpack interchange
knobby
can anybody tell me if the powerpack part # 0582508 will change out with any other. I have access to a 0582556, a 582125, 582452, 583110 and a 583167. will any of those work as a replacer for the 582508. thanks, Knob
alcan
Re: 15 hp evinrude powerpack interchange
Hi Knob #582508 is an ignition coil not a power pac.
knobby
alcan, where did that number come from?
alcan
Sorry Knob my fingers and mind don't always work together. OMC part#582508 is an ignition coil not a power pac.This info is from an OMC master parts price book. I do not have a parts catolog for your year model 15hp. So I can't tell which power-pac you need. Can you give me the part# on the one you have now.
knobby
alcan, I'm the one with the short circuit upstairs. that part on mine is 582285, sorry about that. I appreciate your help. Knob
alcan
Hi Knobby<br />Sorry, as far as I can tell from my books, that is the only number that will work.
Boatist
Knobby<br />Before you change that pickup coil check the flywheel Keyway as very cheap and will cause both plugs not to fire. Very common for it to shear after flywheel has been off.
knobby
thanks for the good advice alcan & boatist, I appreciate your help and will update you when I get'er going as to what happend Knob
