bigboat606
- Joined
- Sep 6, 2009
- 52
My 1987 2-stroke 15 HP Mariner starts fine cold or warm but 30 seconds after start, it begins to run a little rough and the idle speed begins to slow until it finally stops. If I pull the primer level (inject more fuel) the idle speed picks right back up to where it was and then a few seconds later the idle speed slows back down until I pull the primer level again. This can go on indefinitely. I have not had a chance to run the motor at high speed (it?s on the flusher), but if I move the throttle plate on the carburetor the engine revs up nicely. I did take the carburetor completely apart and inspected all gaskets and passages (including the integral fuel pump) and all looked good - no dirt. I squirted aerosol carb cleaner through all the small passages including the low speed adjustment needle seat. I then blew all the passages out with compressed air. After reassembly the engine ran the same. I am stumped and looking for some good advice. By the way, this engine is run on the flusher once a month and it always starts on the first pull and idles perfect (including last month)?until today.
