Sylva-Ranger
Thread starter- Joined
- Jan 17, 2016
- 167
1994 15 hp Johnson 2 strokes, start good, run ok a hi or medium speed........But idle, run good for a short period (1-3 minutes) and stop sudently.
Need choke to restart, It' like lean mixture. after restart run good at all speed but stop again if idle for 1-3 mins
Carburetor is very clean , try many diferents adjustements for idle mixture screw and/or float setting and always the same........... ......Synchro for pick-up point is ok.
fuel pump pressure is good, when stop the carburetor not empty of gaz. the primer bulb always stay normal (hard).
Try another fuel-tank/hose whit fresh gaz and do the same.........
Thinking it's air leak someting........Not make pressure/vacuum test but i Removed the powerhead, put new gaskest,crankshaft seals and piston rings and no change, exept maybe little bit more smoth idle than before, but stop again after 1-3 mns of trolling.
........Reeds valves, cranshaft bearings etc are good. Exhaust is clean (no carbon).
Do the same whit the hood on it or not.
It's like the carb itself have someting .........It's the carb whit plastic cover on the top.
