15 x17 Propeller
kiltedmedic
Just curious, 15" x 17 pitch prop- good for towing a tube on a 19' Sun Runner with a 170 hp Merc 470?
Texasmark
Pulling a tube, including tractor tubes doesn't amount to that much load. What is your current WOT best trim position RPM with your current prop? What is Mercury's WOT engine operating range recommendation for that engine?
QBhoy
It would...but if you aren’t in the know already...I’d spend the money on making sure that water pump lip seal is ok as well as the shaft it’s on. Just a thought.
