jere baker
Thread starter- Joined
- Jun 29, 2002
- 5
1980 e150trxcs motor.idles like a champ accelerates slow, top rpm 4000, prop 15 x 17,speed 35, gas hog big time, large amounts of spit back, under hood covered with oil.<br />Work done so far; carbs removed and cleaned ( were very clean ) checked inlet needle and seats OK,compression check 3 cyl at 100lbs,2 at 95lbs and 1 at 90lbs, pulled reeds, reeds lay on cage with no light visable. none broken or chipped. Pulled exhaust plate, small amount of carbon ,none around ports.<br /> Am I headed to the store for pistons or have I got other problems. Not use to boat motors but do know 2 cyles and 10lbs of differants won't make a snowmobile motor run this bad. I have rebuild a 150 for a friend of mine but have know experance at trouble shooting boat motors.<br /> I need someone to stop me before I start buying things because I can't stand to have a motor not run right, and of course this has to be mine.<br /><br /> Thanks.
