force 150 fl
Thread starter- Joined
- Aug 22, 2003
- 46
I have a 1991 150 force ob that I rebuilt last year . It has good compression and starts up no problems and runs good but it smokes a lot . I try external fuel tank with a fresh mix 50:1 and still the same problem . I replace the carbs with new ones and still smokes the same . I notice when I was doing my compressin test a lot of raw fuel spraying out of #3 cyl only and it had good compression . Can a fuel pump cause this problem and lead to my over smoking engine ? or could I have a broken reed valve or something in the lower end (crank seal broken )? sometimes I will see oil drip from my exhaust port after running with ears in my driveway . Thanks for any input I can get ! 150 Force Fl
