fishcrazy101
- Joined
- Jul 21, 2010
- 17
Just curious if it makes any difference what kind of oil you should use. Is it necessary to use Johnson/Evinrude product or is any brand as good.And if you change brands do you need to avoid mixing them or just pore the new in the tank? Main reason Im asking is someone said that they had experiences where their OMC motors had been sensitive to the type of oil that you put in them. So Im going to try some pinnzoil as they suggested and see if it makes any difference. His take was that he couldnt slow troll with certain oils as they made the motor slow speed operation poor. I have been using Johnson/
Evinrude oil.
I also feel like this thing is really sucking down some oil. Its just a feeling as I have not particularly scrutinized the usage. Is there any adjustment on the mixing or can they get out of adjustment and pour more oil in than they should. Have heard many say they would disconnect the pump and just premix it. I dont think I wan tto do that but want ot make sure this is mixing properly. I do have low oil and no oil lights on the dash and have no problem indications but was curious if there is required maintenance on these.
THANKS FOR ADVICE.
Evinrude oil.
THANKS FOR ADVICE.
