150 Mariner Compression Loss 2 Cylinders.
WRIGHTWARREN
I Have A 150 Mariner.went To Lake,started Right Up,wot And Started To Plane And Then It Started Making A Knocking Sound And Died.started It Back Up And Still Knocking But Got Back To Ramp.got Home And Checked Compression.1 And 2 Cylinder Have No Compression.the Other 4 Have Around 115.what Would Cause These 2 Top Cylinders To Quit At Same Time? I Was Told There May Be A Compression Relief Valve Keeping It From Having Compression But I`m Not Sure.any Ideas Or Help Would Be Great.thanks
bully-85
Re: 150 Mariner Compression Loss 2 Cylinders.
more than likely you burnt a piston and or broke some rings. inspect the spark plugs for signs or molten aluminum ( dry grayish color). if you have access to a flexible light that you can get into the spark plug hole look toward the center exhaust side and inspect the piston edges for damage.
WRIGHTWARREN
All I See Is A Little Bit Of Carbon.nothing Out Of The Ordinary.is It Normal To Lose Both Top Pistons At Once Like That?
j_martin
Usually a cooling problem will stick the top two pistons like that. If you borescope it you will find aluminum stuck to the cylinder walls.
sorry
John
WRIGHTWARREN
Thanks For The Info.im Going To Pull The Heads And Have A Look.both Pistons Still Move Up And Down When The Engine Turns Over But Im Sure The Walls Are Scored And The Rings Are Shot.thanks
WRIGHTWARREN
yep,just like you said.pistons are shot and walls are scored.i think i will find another outboard rather than fix this one.thanks for the help and info.
