Re: 150 Ocean Runner losing power when warm
You can insure oil usage by keeping a line marked on the side of the oil reservoir and noting whether it has dropped.Calculate the oil usage verses fuel consumption.Also make sure the the pickup sock in the oil reservoir is clean and clear and the oil primer bulb stays firm.You could reprime the oil line up to the vro pump by disconnecting it at the pump and repriming until a solid flow is noted and then reconnecting.Any time the oil sysytem is serviced or reprimed ,it is required that you mix 100/1 in the fuel tank until you can verify oil usage from the oil reservoir.The only sensor that initiates the s.l.o.w. is the overtemp sensor.However,It has not been established that the engine is going into the s.l.o.w. mode.<br /><br />What do the sparkplugs look like after a water run? Do they have oil residue on them or are they dry?They should be at least damp with oil residue.According to your symptoms ,I don't feel you are chasing an oiling issue ,but rather an overheat or intermittent igniton failure.In order for me to assist any further ,you'll need to answer the questions posed in my earlier replies.Trouble shooting is a process of elimination procedure.
