150 only fires on 3 of 6 cylinders
GunnerO
My Johnson 150 Faststrike (1994, J150GLERA) is only firing on half it's cylinders. After this problem first started I changed the power pack - didn't help. I also disconnected the shift switch - didn't help. Checked the compression in all 6 cylinders - all good. Checked the spark - 1 side was good, the other had nothing.
I really thought the new power pack would solve the problem. I'm not much of a boat mechanic and I'm out of ideas. Anyone ever heard of this problem. Or better yet, anyone know how to fix it?
boobie
Re: 150 only fires on 3 of 6 cylinders
Could be a bad stator. Two seperate circuits, one for each side. Or bad connections.
cfauvel
Timer base is anotherr option as culprit, but I agree with Boobie, most likely the stator. Get yourself the tools to diagnose the problem before spending more money with guesses.
boobie
Sorry but no timer base on that mtr. It has an OIS sensor. Agree with cfauvel, you could use proper meters and an OEM service manual. The manual will be good for future use. Stay away from Seloc or Clymer.
Chris1956
Honorary Supreme Mariner
Check the overheat sensor on the heads. Disconnect them and see if spark returns.
boobie
I'm curious. What do the overheat sensors have to do with no spark??
Chris1956
Overheat sensor will activate S.L.O.W. system, which kills spark to 3 cylinders.
cfauvel
Not sure if anyone mentioned this either, but a stuck shift assist switch will kill 3 cylinders on the starboard side...what side is dead?
boobie
When SLOW is activevated it stumbles ALL the cylinders above 2500 rpm. Below 2500 rpm the mtr runs normal even tho' the overheat horn is blowing from being tripped by the overheat sensor.
aerobat
i am not sure, but i also dont think SLOW cuts 3 cylinders on one bank. imagine the roughness respective the running possibilty of the engine. it due to my knowledge slows all cylinders.
