150 txrc carbs?
erniefish
motor was running a little rough, so as usual i figure time to do the carbs,(this is my second yamaha spanning 20 yrs, a usual spring ritual) worse since e-10. now it runs terrible , while trying to get on plane(no power) spray gas in a atomizer through top carb set= pick up in rpm, at idle, spray fuel in #1 carb set=no change,spray fuel in #2 carb set (idle) ,rpm loss, spray fuel in carb set#3(idle) no change, pull plug wires on 1,2 5,6 no change, it appears to have spark,do i have multible issues? this has me on the ropes, new racor 10 micron, i tried remote tank, cleaned carbs 2seperate times once with ultrasonic machine, any suggestions would be appreciated, thanks e:mad:
