150 v6 lower on a V4
jeepster21
I recently bought an 89 evinrude 110 with a bad lower unit. I have a lower unit that i got cheap off ebay. it was from a 1995- 2000 evinrude 150. The guy I bought it from said he had it on is 140 v4, all he had to do was change shift shafts from the v6 to the v4. will it work on my 110?
thanks
WillyBWright
Re: 150 v6 lower on a V4
Welcome to iboats.:)
Too bad you didn't drop in and ask before you bought it. I don't think so unless it's a commercial motor. The V-6 gearcase fits 120s and up for some years.
Dhadley
It'll work just fine. Yes, you'll have to use your shift shaft and - obviously - use a V6 prop. Two other things to note, you'll have a little more drag from the larger gearcase but you should be able to mount the motor a little higher because you'll be using props that are a full 1" larger, or more, in diameter. Most likely those two factors will about cancel themselves out.
You'll probably use a prop with less pitch than you would with a V4 case because of the different gear ratio.
jeepster21
thanks for the input. i forgot to mention that the lower unit has a bobs machine shop nose cone and low water pick up on it so i should be able to rais the motor sky high to reduce the extra drag produce by the bigger lower unit. thanks again for the help
Dhadley
Yep, you'll be able to run it a bunch higher. The extra length may still slow you down unless you're at or near gearcase blow-out speed now.
Jeb1971
Hey Jeepster,
How did your boat run with the nosecone and low water pickup?
John
