subseacarnage
Thread starter- Joined
- Feb 9, 2007
- 3
I have a new vmax and have not completed the break in yet and have had the alarm go off after taking off a couple times after a series of take offs. When the alarms goes off it sputters and I will stop and let it idle till it cools down and then it seems to be okay unti thye next time it does it. Is this normal?
Also I noticed on the break in that you have to premix the oil/gas in addition to the oil injection system. I have run it through the 3rd through 6th hour w/ out adding oil to the gas. There was about a 1/4 tank premixed gas in it before i filled it up. Is it possible that I have done any damage? Most of the hours were at low speeds since I was in a creek and wasnt familiar w/ the bottom and I probably have an actual hour of 3000rpm or more.
