15a micro fuse on 5.0 tks alpha
RussGT209
Arggg
had the alternator rebuilt, set the base timing to 10deg, and she still backfires at around 3000rpm. It'll run fine all day at less than that, and if I nurse it up to a plane (which is very difficult) it runs fine, but it is not at all happy with any real load.
RussGT209
Fuel is good, I did a compression test and all cylinders are 145 to 155. The plugs were "dry sooty" I attribute that to timing issues from the wonky rectifier, but what do I know? Took care of the plugs and a suspect coil lead, and it is running great! I will check the plugs again after some hours to make sure there are no other issues.
thank you very much for all the advice, it has been a great help. Happy boating from Vancouver!
