15hp 1986 evinrude milky stuff in prop
little lulu 2 boat
my 86 15hp evinrude started having milky oily stuff in prop will this hurt it what could it be from how should i fix it ty for helping
jtexas
Re: 15hp 1986 evinrude milky stuff in prop
couple possibilities.
might be unburnt engine oil dripping from the exhaust. not uncommon, especially if you been trolling alot. no cause for alarm. decarb your motor soon as you get a chance.
or, it might be gear oil in which case you might need new seals for your lower unit. you can check for this by looking for water in the gear oil.
little lulu 2 boat
thanks ill check on decarbing gear oil looked good no water motor also seems to get hot i can only hold hand on baffle plate 3 sec after running is that normal
