luckystriker
Thread starter- Joined
- Sep 1, 2009
- 11
Went out over the weekend for a run. Engine ran OK for two or so hours. Towards the end of the run, a misfire type symptom appeared.
With WOT and low RPM this "misfire" happened every 3 or 4 seconds. I checked the bulb and release valve on tank and that all seemed fine.
For a few minutes, "forward" would also not engage, but eventually did.
I need help listing where to start looking and where to stop looking ( Most obvious and less expensive to the extreme.
Outboard is 15HP code: 152HA (1976-1977 i believe)
Edit: It starts and idles just fine.
