15hp gamefisher ign. bad?
MichaelMullis
Top wire fires fine, no fire on bottom wire. accessed coil/ condenser/ points. <br /> Top coil .7 ohms<br /> from plug end through coil 64.5K ohms<br /><br /> Bottom coil .7 ohms<br /> from plug end through coil 7.65K ohms<br />Big difference. double checked, same reading.<br />coil and wire are made together as a unit. looking at these resistances I would think that the top wire would be bad but it was the one that was firing. Any Ideasa/ <br />have a safe and good day<br />Michael
steelespike
Re: 15hp gamefisher ign. bad?
Switch the coils if the problem follows change the coil.
