jfadool
- Joined
- May 25, 2009
- 119
I have a 15 Evinride that I think is hydrolocking. I think that a large amount of liquid fuel is getting in to the cylinders.
One of the users of this engine said that one day it just stopped working. So when I get to it I pump the fuel line bulb and notice that it is not getting hard. It gets firm but I can still pump fuel through it. So I think ok give it some pulls and see what happens. Well it is hydrolocked.
I assume that the float valve is not seating properly. I pull the carb and everything is spotless. I still pull the valve seat and the spray it clean with some carb cleaner. I also clean the valve its self. I then do a full carb clean because I have it apart anyway. But everything already looked great.
I put the carb back together and I check that the valve is seating by trying to blow through the fuel inlet while pushing the float up and it stopped the air. When I let the valve down I could blow through it.
After reassembly the bulb still would not get hard. And it would still hydrolock.
I tried to get all of the liquid out of the cylinder by just turning the flywheel and that worked but I could not ever get the bulb to get hard.
Should I just put a new carb kit in it, or is there a different thing that could cause the hydrolock.
wow long post and no pictures, sorry.
James
James
