Wondering if any of you have experience with a small outboard that lacks some power at the top end. 1984 Force 15hp.
If I choke it a tiny bit (not to the first detent) it picks up and seems to run as it should...push the choke back to normal run position and it picks up a tiny bit more before quickly bogging back down. Runs fine there, but just lacks that extra bit of the power band.
I cleaned the carb - no varnishing or anything ugly. The main jet is a fixed size, not adjustable. Adjustment screw for idle mixture. Replaced fuel pump diaphragm and cleaned filter screen. Fuel hose/bulb is new. Points have been cleaned and adjusted. Plugs are new and gapped correctly.
I assume that it's running lean (by reducing airflow with the choke it runs better - too little fuel or too much air??)
Thanks in advance.
Thanks in advance.
