northshoremb
- Joined
- Jul 25, 2009
- 18
I just had my 1980 15hp Evy tunned up buy dealership 2 weeks ago and it ran perfect except it would load up when trolling then wanna stall. I went fishing and all I did is throw into neutral and rev it then back to trolling for a minute. Then few days ago I went out and it would totally die if I even tried to go less then 1/2 throttle. You would need to pull it over a few times and rev the **** out of it. I went home and mixed up some gas with a 75:1 ratio with fully synthetic to see if for some reason the 50:1 was the issue. I went out and the motor ran the same way and sometimes ran on 1 plug at 1/4 throttle and needed to crack it to clear it up and run on 2. Took it out of water and put on the muffs and changed to NGK BR7HS with .030 gap like some people said. Still it runs like **** and need to fool with choke in and out even at full throttle and won't even wanna run at 1/2 or less even with choke closed or open.
Anyone have any idea what the BLEEP is going on???? Can it be a coil or something? I am losing my mind cause it for sure run good with 75:1 and properly gapped plugs. Would for some reason have something gotten into the carb and jammed it? Is it hard to take apart carb to check?
