15hp wot problem
Riverrat47274
I have a 83 Johnson 15hp,just rebuilt carb,new fuel pump & plugs.idles good but won't run once it gets past an idle.
Daviet
Re: 15hp wot problem
Compression OK?
Have you tried pulling one plug wire at a time to see if both cylinders were firing?
When you had the carb off, did you remove the high speed orifice and make sure it was not plugged or restricted?
Try pumping the primer bulb constantly and see if it helps.
Riverrat47274
Compression is good and both coils are fireing.will try the primer bulb trick and see what happens.thanks
Riverrat47274
Does the timeing mark have to be dead center when it first starts to move the cam follower?
