16' boat on 14' trailer?
davkrat
I have a 1992 Shore Land'r model B148/1610. On the newer trailers it seems the tongue is adjustable in length but on mine it comes to a T at the first crossbar and there is no room to extend it. I believe the newer trailers are the same for either 14' or 16' boats you simply adjust the tongue to suit.
I currently have a 14' Valco V hull that I use for fishing. I want to get a 16' Jon boat (Lowe Mod-V) to use duck hunting and would like to be able to switch between the two hulls on the same trailer. It looks like I could scoot the winch post forward almost a foot without running in to the tow vehicle. The fact the spare tire on my Jeep is right there is a bit of a nuisance. Was also thinking I could maybe extend the bunks back 6"-12" and hopefully not totally throw off the tongue weight. Perhaps a shorter arm from the winch post to the hull as well.
Any other advice or options? Perhaps I should just buy a 2' longer 3" post to replace the current tongue with? The model number of the trailer being B148/1610 makes me ASSume that these trailers may have been useable with 14' or 16' trailers but that's just an ASSumption :)
JimS123
Re: 16' boat on 14' trailer?
Model numbers indicate boat length as well as weight capacity. Research yours to see what's what.
If you have enough capacity simply replace the tongue with a longer one.
The last time I saw a boat that was 2 feet too long, the frame cracked in half because the boat was cantilevered too far out the back. It made for quite a mess at the launch ramp.
davkrat
Yeah definitely won't be cantilevering the boat and motor 2' off the back of the bunks! That's just stupid!!!
smokeonthewater
don't extend the bunks as they will be un supported and able to flex down right where you need em most... transom should be directly over the last bunk support bracket... IF the trailer can be lengthened it will be at the front
show us pics and we'll have a better idea... fwiw rule of thumb is trailer needs to be a minimum of 10% longer than the boat measured from last cross member to coupler
a swing away tongue is an easy way to add a foot or so of usable length IF the frame is up to it
