16' Demcraft Ski/Fish Boat
robfurman
Guys,
My Transom on my 1972 DemCraft that is showing wear and I'm assuming buried in between the fiberglass is some type of wood that seen better days.
Story:
I was taking my boat out the other day and noticed water slowly dripping from one of the bolts that secures my motor to the transom. Looking closer I noticed a slight gap between the motor mount and the outside of the transom. This was more apparent on the right hand side (Standing from behind). The bolt did seem a bit loose, but as I tightened it you see where it's starting to push the fiberglass on the inside in a bit. Besides ripping it all apart does anyone have an good ideas? I was thinking of placing a wider metal plate under the bolt or maybe across both bolts to give better support?? Btw, my bolts are secured from the inside.
Any thoughts?
Robert
