16' Nescher ski boat complete restore- SPLASHED!!
archbuilder
Re: 16' Nescher ski boat complete restore- SPLASHED!!
Thanks Emberblade, hopefully what I have posted will help you out. That is the name of the game around here. Think I'm going to stick with the template Wood, I can see that 3m double sided tape being hard on the paint if I get it in the wrong place!
Last Mohican
When I mocked mine up I used double sided tape to stick the platform to the bracket. I then used packing tape to mock the whole thing to the boat.
archbuilder
Ok she has a new butt....just call me plastic surgeon to the stars, lol. I've got an early meeting tomorrow...so I'm calling it a night..I will post the complete "surgery" pics tomorrow.
archbuilder
Ok here is a shot of her new butt! I still need to drill out the rest of the bolt holes tonight and add the rubber pads, but the hard part is done. I have more pics of how I laid it out I will post later.
Triton II
Looks great Arch. Now you've got a teak butt, how about a teak rimmed steering wheel to match? :)
TII
KnightWolf
LOL time to start in on the steering wheel again:D
archbuilder
That is next years project....You guys will just have to settle for a gas tank and swim platforms this year!
KnightWolf
Well if your ok with a butterface ya know dang she looks good great butt....but her face! (or steering wheel)
Ha Ha just kidding ya know we all love Miss Morgan. I actually totally forgot about the steering wheel. till it was just brought up.
archbuilder
Great, now Mick will probably pop in and say " I told you so, you need a different steering wheel!" Fine, so next winter I will try the stainless again and come up with a custom steering wheel for her!
archbuilder
Here is the step by step on the layout...which I'm sure you all know is the hardest part. I started by "leveling" the boat, which of course is finding a reference surface that is level with the horizontal plane. Easier said that done on a boat, you need a freaking surveyor with all the curves. There should be a law that manufactures have to provide some bench marks for us to reference in a rebuild! I don't know how many hours I have spent measuring to round corners to square things up or find an angle :mad:.....there is no good way.
I did figure out during the build that the top of the transom is more or less "level" that is parallel to the two "ribs" that run from it towards the bow. Using the transom as a reference is a bit hard with Max bolted to it. So I used the two ribs, a level and a floor jack to "level: the hull, parallel to the transom.
Once I jacked it up and got it the hull level I could use the level to layout the swim platforms so the would be "strait across" the back. I also went to great lengths to center Max so he became my second reference point. I needed this to figure out where to place them vertically on the transom and keep both sides at the same height relative to the bottom of the hull....or top of the transom depending on how you think about it. My worst nightmare was to have them at different "heights". I put tape (3M automotive paint tape, pricey but works great) on the transom at about the height I thought I would mount them. I then arbitrarily measured down from a mounting bolt on each side of Max. Now I had two points that were the same height on both sides. That point is the mark with the arrow and RET (should be ref) pointing to it.
I then took the level and then compared the point to the pinstripe coming down the side of hull. You can see in this pick that it is a inch or so above the water. I want the platforms about 2" above the water.
It turns out that the point lined up almost exactly with the pinstripe so I measured up about 1-1/2" and marked where the top of the bracket should be. Then I put a horizontal line on a piece of tape across the back of the transom. I held up the transom with the brackets on it and measured from Max to the inside bracket and marked that. That gave me both horizontal and vertical references for the brackets. Next I laid the bracket / platform assembles on top of some chip board and traced out the brackets and holes.
I trimmed of the top and outsides of the template and taped it over the reference points.....triple checked my measurements....sweated some then drilled two of the top holes! Both assemblies fit like a charm....now hopefully they are the right height and angle...but I won't know that till she is in the water.
I have no clue if that makes any sense...but that is my best shot at explaining the process!
KnightWolf
You are a sucker for peer pressure!:D Still an awesome build on her! Sit back and enjoy her for a while she is just fine!
seamorewaterVIP
who ever has Micks phone number needs to call him:D hint hint!
archbuilder
EZ I have his phone number, let me know if you want it......should be a good excuse to get her on the lake! I spent the weekend at the lake working on my place. I put in 1000 ft of sod in about 90% humidity.....90 degrees (morning ) or so...then built a temporary sprinkler and put up my sail shade. Works great, I'm really happy with it so far. Here is a shot from my "beer tent", lol.....I love the view and the breeze is nice off of the lake. It was a little over cast and right before the sun went down.
Woodonglass
Honorary Supreme Mariner
WOW!! Lake is REALLY Down!!!!
archbuilder
actually it is at "normal". They usually keep it 2' higher in the summer, but for whatever reason they have lowered it this year. They dumped 2'-6" out of it in the last two weeks. My neighbor says they are keeping it lower than normal because of some bridge building they are doing around the lake.
Triton II
Your lakeside place looks awesome Arch... very cool. (Green-eyed monster warning!) :)
TII
archbuilder
green-eyed monster? By the way my sail shade is an Aussie product, works great so far. We'll see how it fairs against the OK wind.....that is something we don't have a shortage of! lol
