bucket of rivets
Thread starter- Joined
- Feb 26, 2012
- 47
In my search for another small tinny today I stumbled across two boats, one I believe is a 15' early 60's Starcraft Voyager, the other is a 16' 2" long 71" beam width Starcraft Jupiter or similar model. (the measurements really don't match any of the 16' early 60's models, with the options being Juptier, Starmist, and Stardust. Its got the huge splashwell and definitely measures 194" long, by 71" wide, too narrow for an early Jupiter, too wide for the Starmist or Stardust. Its the older flat bottom hull.
Both are $350, boat only no trailer, no motors.
The Voyager has a new plywood deck and new Seacast poured transom, all done by a local boat builder, who is selling the boats after owners failed to claim them. Both have been sitting for several years under a huge lean too storage area.
I was really after another tinny but the fresh deck and transom on the Voyager certainly caught my eye, as did the added space compared to the tinny with it's huge splashwell. (The Voyager has a rather small splashwell and much more room is left in that boat for fishing.) The downside to the Voyager is the short 15" transom and lower gunwales. Its been repainted at some point, both the blue upper and white lower are peeling pretty bad, bad enough that I could probably remove the rest of the paint with an air blower and compressor. Its also got a small crack in the plastic windshield.
On the 16' aluminum hull, its in need of a deck and transom job and has a scratch/scrape on one side down low, below the water line. Apparently someone dragged it across something somewhat pointy and it left a mark that looks like a little more than a keyed car door scratch, but at the end, there's a puncture, which someone welded. Its the weld that is now cracked in several places, still adhered, but cracked across the weld bead. He didn't try to hide it, he pointed it out and said the best way to fix it wasn't to weld it but to use epoxy and Gluvit the inside, then use marine Bondo to cover the repair for cosmetic purposes. He don't mess with aluminum boats and has no interest in fixing it.
I got the impression he bought it for its motor or some other parts. Its also missing it's windshield. I have a suitable glass windshield I can use if I go with this one.
The deck and transom are minor in my eyes, its the leaky repair that concerns me. The entire area is no more than an inch long, the length of the weld. The weld could certainly be epoxied over and sanded smooth. It appears they welded it from the outside since the inside area is under a rib.
It looks like the weld shrunk and cracked, the seller said that they had silicone smeared all over it and couldn't figure out why it leaked so bad. I couldn't find any other damage other than the fact its got about 20 or so misc holes drilled in the transom from past fish finder transducers.
Would anyone get involved with the aluminum boat?
How much of a drawback is the shorter 15" transom?
(I'm thinking safety wise here, I can bracket any motor, and I've even got several short motors I could run on it, but the plan is to run in saltwater, where a taller transom can be nice).
Basically both will need paint. The aluminum hull, while being a 20" transom, needs a weekend or two of wood work and some metal repairs.
