I have an 88 Renkin Cuddy 20ft 3.0L Mercruiser 165 I/O. I put it in the water and almost sank it because there was no drain plug. I put in drain plug, took it back to water. the engine runs fine, then all of a sudden it starts to smoke in the cuddy. I look to the stern side and see water coming into the boat. the engine is too hot to start so i didnt force it. I vertially swam the boat back to the dock; by then its full of water all the way into the cuddy. There is no hole in the hull and doesnt seem to be at the transom but i can't see behind that. There is a hole in my bilge pump hose, but i didnt have it on. The 50/50 antifreeze that i filled the radiator with is now almost gone. After cooling, the boat starts on first crank on the Rabbit Ears water hose flusher, the temp remains fine. Where did the antifreeze go ,and where did the water come from into the boat? The hull is fiberglas. How can i tell if the transom is one of the problems for the leak?
