Bob Gutkowski
- Joined
- Jun 10, 2012
- 7
I have a 165hp mercruiser and I have experienced high temps due to water impeller damaged. Engine wouldn't idle and would get hot. Stall when moved into gear. Replaced impeller but installed backwards removed installed correctly with all new parts.Then I changed the intake manifold gasket and noticed the gasket wasn't sealing correctly. I used solvent sprayed at the gasket increased rpms significantly. Rather than machine intake manifold surface I used ultra gray and now it wont start.
Also I used the garden hose on the impeller pickup tube without engine running and filled up the exhaust manifold and oil pan with water. I drained the oil and water replaced filter and oil ran engine to get water out with plugs out. Replaced plugs. replaced exhaust manifold gasket after inspecting manifold.
Question the manual doesn't recommend sealant on the intake gasket but my friend use it always. I wanted to know did I affect the amount of air to the intake manifold by sealing the gasket for no leaks. Is the gasket suppose to breathe air.
I cleaned plugs many times and no help.
Now I'm going to clean inspect plugs for fowling and try one more time.
I never had problems starting this engine until I sealed the intake manifold gasket.
