165hp Mercruiser In-Line 6 Oil Sender
golbrick7
Want to by-pass exisiting wiring due to corrison, rat bites, etc. Would like to hook up oil sender to oil temp gauge. Can anyone help?
Fishermark
Re: 165hp Mercruiser In-Line 6 Oil Sender
Do you really mean oil temp gauge? Or do you mean oil pressure gauge?
You can always run a wire all the way from the sender to the gauge - or splice into the harness anywhere along the way.
golbrick7
The gauge is marked as:
Top portion is: 0 40 60 80
Lower portion is: 0 200 500
Ayuh,... Do you have Both senders/ sensors,..??
