16v output from Johnson 112spl
gregBR549
I have a Johnson 112 that is putting out up to 16 volts at WOT and about 13v at idle. From what I have read, this is normal and by design. It is unregulated from the factory. It only has a rectifier, not a regulator. Is that right?
My concern is overcharging the batteries and (more importantly) frying my electronics. My depth finder manual says operating voltage from 10-15v. I am considering using a 12v zener diode in parallel at my electronics to protect them. Is this a common fix? How about overcharging the batteries and getting fumes in my bilge. Should I be concerned about that?
thanks
Greg
John_S
Re: 16v output from Johnson 112spl
I have an unregulated outboard, and when the battery is fully charged it can climb to 16V while underway. I turn on some lights, airaiters, live-well pumps, etc to keep the voltage down.
bruceb58
Honorary Supreme Mariner
You can use a zener but you have to put in a resistor in series to limit the current through the zener. Note that you will have a voltage drop across the resistor as well so take that into consideration and it will be drawing power at all times, even when the device is turned off. You would be better off just using the resistor to drop the voltage or just 2 or 3 power diodes in series.
