17 - 18 - 18 - 3 blade - 4 blade????
kryan2
1986 Sportcraft 22ft walkaround cuddy.
350 mercruiser w/ alpha drive
no bottom paint...spotless bottom
Current setup:
20 pitch SS no name prop
4100 max rpm trimmed out
41 mph (non gps speed)
horrible hole shot.
I need to get on plane faster and usually have 3 big fellas with me fishing. I'm not even in the operating range of the engine?
What would you suggest?
junior1113
Re: 17 - 18 - 18 - 3 blade - 4 blade????
i would be looking to be running that at 4500-4600 assuming this is a 3 blade 20p ss prop youd have to go to 3x18 ss or a 4x17ss.
need to have rpms they help hole shot should'nt loose any top end, might gain
i swear by 4 blades they are all aroud just better hole shot, plane time ,lower plane speed, fuel efficiency, hold up excelent in rough waters. even gain top end in some cases
1993 2000 hyrdra-sport
___________________
1993 200hp evinrude
___________________
turbo ultima 4x14.25x17
Tail_Gunner
Current setup:
horrible hole shot.
20@4100
19@4300
18@4500
17@4700
You can pick your WOT rpm range and apply it to the prop you choose. If you go to a 4 blade just drop another 100 for the 4th blade. Now if you would like total all around performance a 16p Stilletto 4 blade BayPro would wake that boat right up and probably increase your top end speed.
Dont let the 16p startle you. it will act like a aggressivley pitched 17 3blade.
