17' 1965 OMC deluxe
garyq
what should I be concern with ,when thinking of buying this boat hull wise. also is this a good design tri hull has 150 hp gas motor lots of info needed thank.
parrisw
Ensign
Re: 17' 1965 OMC deluxe
Great old boats, I'm restoring a similar one now, its a little different but still an old OMC boat. ITS OLD so likely has rotten wood unless someone has already replaced it, I thought mine was good when I bought it, but I was surely wrong.
garyq
I hope it all goes good and no major wood rot
Bob_VT
Welcome to iboats.
Do you mean it has a little rot? Do some SEARCH for test holes or bore holes ...... afraid to say but rot starts on the inside and works it's way out....so what appears as a little might be allot below the decking.
parrisw
Ensign
Trust me, if that boat has never been touched, it's going to have rot, unless it's spent its whole life in dry storage.
ezmobee
If that's an inboard motor, I'd imagine parts are going to be near impossible to find for it.
parrisw
Ensign
I thought all those ones were inboards? But arn't they just a 2 stroke V4? like and outboard? Wonder how many parts are the same. It's more the outdrive that I'd be worried about getting parts for. Any OMC stern drive is hard to find some parts for.
ezmobee
Some were. His being a 150HP though it could be a car motor of some sort. Either way it's gonna suck for parts.
garyq
I was told by the owner that the engine 150 ph merc an that the motor was original from 1965 gas only is this going to be hard to find parts LOL..
ezmobee
There is no way there was a Merc originally on an OMC boat. OMC made Johnsons, Evinrudes, and OMC stern drives. One of their boats would have been equipped with one of their powerplants. Are we talking about an outboard boat? If so, a Merc could have been swapped onto it at point.
garyq
no this is an inboard only gas only merc 150 hp. unless owner is wrong, I will ask my friend to get model # for engine and post ...........
garyq
nice work on your boat ,if i get mine I will post pics
parrisw
Ensign
Post some pics then we'll know. But its entirely possible that someone has swapped out a merc inboard and outdrive, that would be cool if it does.
garyq
Next weekend I will have the boat and will sent pic I have to drive 5 hr to get it
or her ...Do most guys name their boats girls ,looking for names too..
garyq
Well okay guys I didn,t buy that boat ,the guy couldn,t fine all paper work and i found a better one not to far away but it is a ford Mercury v6 inboard with a johnson drive gas only 150 hp...the one Im getting is a buick v6 150hp..
ezmobee
and yet again, none of this makes any sense whatsoever.
garyq
Okay what doesn,t make sense explain
Shife
There are three basic types of marine propulsion systems:
1. Outboard - This is where the engine and drive components hang off the back of the boat as a single unit.
2. Inboard - This is where both the engine and drive unit are mounted inside the boat and only a shaft and propeller protrude outside the hull.
3. Inboard/Outboard or I/O - This is where the engine is mounted inside the boat and the drive unit is mounted outside the boat.
There are jet drive variants of both the outboard and inboard drive systems, but not the I/O. While most of the marine engine systems, especially inboard and I/O, are based off of automotive powerplants, they are typically proprietary and mixing one brand with another is usually cost prohibitive.
So..... figure out what in the heck you actually have and get back to us.
garyq
its I/O - thanks for the schooling
