I am brand new to the world of boating. I just bought a used (not sure of the year) 18 HP Johnson Seahorse. I tried to take it out on the water yesterday and couldnt get the darn thing started. On a couple of cranks it would act like it was about to come to life but would go out after about 3 seconds. The carb has been recently re-built but the motor hasnt been ran in a couple months. Every once in a while the motor would backfire when it was being cranked. I might have had the set up wrong when trying to crank. I had the hand control on START, I dont know what the "lean" and "rich" control does, so I had it in about the middle. But I'm not sure if I had the thing in the right gear. I'm assuming it has foward, neutral, and reverse and should be in neutral when starting. I had the gear shift in the middle (thing is not labeled) so im not sure if i was actually in neutral. If it sounds like the thing is set up correctly and just not starting, let me know. Or if it wouldnt start and i had it set up correctly let me know what it sounds like needs fixing.
<br />Thanks for any help!
