Irv964
Thread starter- Joined
- May 3, 2008
- 315
I am really baffled on what to do? Some say I need an 18 pitch while others say I need a 19 pitch? (3 blade)
I am looking for more holeshot and less cavatation in the turns. I have a 2007 90 H/P Merc 4 stroke with a 2:33 gear ratio and it is mounted on a 2006 Lowe 165 Fish & Ski Aluminum boat, I am currently running a aluminum 19 (3 blade) pitch prop but I get a lot of cavatation in the turns which requires lots of trimming down to avoid.
What are the big differences between these 2 props in Stainless? I don't necessarily want to loose too much top end speed but I realize I can't have both, which one would work best? I am really after holeshot and less cavatation, we do a lot of tubing/skiing. Thanks for your help.
I am thinking this one below or I can get a used Merc QuickSilver Stainless 13.25x19 for $250.00?............Irv964
Advantage I Stainless Steel Propeller for Mercury, Mariner, Sea Ray Mercury & Mariner 90 HP (2 & 4-Stroke) (Thru Hub Exhaust & 15 Tooth Spline)
Prop Specifications:
SKU: 11319
Pitch: 19?
Diameter: 13-1/4?
Blades: 3
Rotation: Standard
Material: Stainless Steel
SKU: 11319
Pitch: 19?
Diameter: 13-1/4?
Blades: 3
Rotation: Standard
